Ever questioned yourself if is it possible to connect a car amplifier to your hi-fi? Now here's the tutorial
Enjoy your car amplifier with your home sound or even your car speakers
NOTICE 2: I'm not held responsible for any loss or damage to any of the equipment or yourself. This is utterly for experimentation purposes and am not responsible. DO IT AT YOUR OWN RISK!
Hope you enjoy the tutorial!
If you need any help or more images, just tell me!
My sound setup:
- Get a normal Power Supply, make sure it has at least 15 Amps for a 400W-500W RMS amplifier.
- Secondly get the amplifier and make sure you have the labels of the GND (ground), 12V (12V power connection), REM (Remote or also can be labled as MEM).
- The next thing is to get a 4 pin molex connector which has 2 ends (4 pin male to 4 pin female or whatever) This is used so that you don't cut the PSU wires and damage permanently the PSU.
- Connect the YELLOW 12V line to the 12V socket of the amplifier. Connect the ground BLACK wire next to the yellow wire to the GND socket. Now for the REM, we need to do a loop, just cut the RED wire from the 4 pin molex(or any other wire of the PSU - I used RED to show you) and connect it to the REM socket and to the 12V socket. This is to bypass the connection of the CD stereo used in the car to control the volume.
- Now for the input, use male RCA plugs to 3.5mm jack and connect them to the input sockets of the amplifier.
- Connect the jack to an MP3 or your PC and you can listen to music.
- Connect the speakers using the speaker + and - sockets.
- Now we need a small trick so that when the PSU is plugged in and switched on, it switches on. The trick is to find the green wire of the 20/24pin motherboard connection, connect a wire to the green wire and to the black wire near it so that the PSU turns on.
- Once you done this, turn on the PSU and the amplifier LED should come RED and then GREEN when voltage has stabilised to 12V.
- Now for the final touch, make sure the voltage knob (or volume or sound knob whatever you can call it) of the amplifier is set to minimum as possible, and the audio source to 1 at first. Continue turning the knob of the amplifier volume bit by bit until you hear sound coming from your speakers. Now turn the source volume to full until it is heard normal. Continue turning the volume of the amplifier until you hear distortion. When distortion occurs this means that that's the max it could go as well as for sound quality.
NOTICE: Make sure you watch the 12V Green LED while you turn up the sound. Seeing the Green LED light dimming or blinking if the volume is turned up a lot is the sign of stressing the Power Supply! Make sure you have a stable green LED which does not blink or dim!!!
My sound setup:
(if the amp contains big enough capacitors it "might" be able to output 2000W for a fraction of a second) IMHO the marketing teams for car amps just invent the numbers out of thin air. They are even worse than the home theatre marketing teams. Probably as bad as whoever decided that Qtek could call there PS Powersupply 600watts
