Crucial RealSSD C300 256GB - What am I doing wrong?
Man of Honour
9 Jan 2007
Metropolis
It should be faster, mine are these:
I did install the Marvell SATA 3 drivers for my controller
Your board also has a Marvell controller, have you done the same?
My controller is also set to AHCI.
The driver is here:
http://www.gigabyte.com.tw/Support/...?ProductID=3234&ost=windows+7+64bit#anchor_os
EDIT: Is it plugged into a SATA 3 socket?
OP
5 Dec 2006
25 Mar 2005
Rocketman I believe the pciide from as ssd bench means you are running in ide mode not ahci.
I think this makes no difference, at least it didn't with my Crucial 64gb ssd and I have seen few people having no ahci enabled in bios and they had full speeds with their drives.
16 Jan 2003
Nottingham
http://img532.imageshack.us/img532/2158/marvell.jpg
The driver is here:
There's a newer driver available btw, also updates the config device driver.
http://www.station-drivers.com/tele...ru4.1.0.1601-all(www.station-drivers.com).exe
Man of Honour
9 Jan 2007
Metropolis
No, its a drive-to-drive clone of my crucial m225 256gb. I had hoped using Acronis TI would save the hassle of reinstalling :(
Is it so much of a hassle to do a reinstall? Personally I would do a clean install with the C300 to see if it makes a difference. Just run the benchmark again before you start a couple of times to confirm that it is still the same as before.
OP
5 Dec 2006
I've done a reinstall, but I still can't get the drive to be controlled by the Marvell driver. The drive is definately plugged in to one of the SATA 3 ports, I've downloaded and installed the Marvell driver off Gigabyte website, and I've changed the GSATA setting in the BIOS to AHCI. I've re-run AS SSD Benchmark, and I'm still not getting over 200 for sequential read :confused:
The drive is listed under device manager as C300-CTFDDAC256MAG ATA Device if this helps, and I have Marvell 91xx Config Device listed under System devices, but it states that no driver files are loaded for this device?
Man of Honour
9 Jan 2007
Metropolis
The only two places where the C300 and controller show up are here are ‘disk drives’ and ‘storage controllers’:
I'm on a ASUS P6X58D, have you tried your motherboard support forum?
