Mine only does/did it when i use 3 screens,1 is fine.
Mine was the same you need to make a profile and mod the CFG file.
Mine was doing it with 1.
Yet to try 3.. ******* display port >:|
Why whats up with the display port? You meaning the adaptor? If so thats an easy fix.
Just buy my Bizlink if you want ?
Think it would be fine, I would crank that 920 to 4.2ish and see what happends.
New water block turned upto day have a Vantage score for you all.
H5 should be ok, Whats your full load temps? If there a bit high try fitting a 2nd fan so its push pull.
Not sure about c0s but have seen the others around 4.2 on air.
Royal mail. They are crap it was only going up the road, and it was sent first class! tossers.
