- 23 Apr 2009
- Cheshire
This PSU is one of the very best, but it isn't cheap and currently out of stock on OCUK. Personally, I think its worth the wait. Here is a review.
Unless you plan on watercooling, I would suggest going for this motherboard instead and this RAM will give you the same performance at a much lower cost.
I would also recommend going for the Asus 5850 card, the warranty is longer, it allows overclocking with the inbuilt software and is cheaper.
