- 22 Sep 2009
Cool setup rancid elf! Thinking of doing a similar with my rig. Where have you mounted your HDD?
I have my 4 solid state drives screwed to the side of the case. 2 on each side.
Please state what drivers you are using and what in game settings for this. I prefer to play BC2 on the 5970 only when using Eyefinity as it is smoother (I am using, max settings with 1xMSAA, HBAO on) - I am using the drivers noted below and found none to be any better and I have tried most if not all of em! Just need clarificaiton to see if I have missed out ...!
Driver Packaging Version 8.74-100406a-098262E-ATI
Catalyst™ Version 10.3
Provider ATI Technologies Inc.
2D Driver Version 8.01.01.1031
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0003
Direct3D Version 8.14.10.0755
OpenGL Version 6.14.10.9827
Catalyst™ Control Center Version 2010.0406.1919.32787
Yes you have missed out. There was a 10.4 & a 10.5 I believe its the 10.5 I used. My settings are all maxed with 4xMSAA, 8 x anistropic, HBAO off.
Can you post the driver info for your setup from the ATI Information panel for cross reference ...
The by product of too much time and too much money!![]()
38.5k gpu score
more to come
Depends what drivers you have. I have some leaked driverds which were posted on here about a month ago and eyefinity with tri-fire is working.
I have 3 x 24 inch screens and run res @ 5760 x 1200 and BC2 rocks. I get an average of about 100 fps with tri-fire eyefinity
@ last finaly broke the 35k barrier. on this hot summers day hit 35413.
Graphics Score 39540 just short of 40k.
here is the link thx to phoenixdancer again for helping me achieve these scores.
more to come .
http://service.futuremark.com/compare?3dmv=2205509
think i might stick a nvidia card in there as well for a improved score.
What OC do you have on your gpu's and what voltage you giving them?
hello there on the gpu,s they have 1.7volts gpu @ 1ghz memory @ 1260 mhz.![]()
kiss goodbye to those cards if you're putting 1.7v through them!
that's lunacy mate, sorry
lol what i was supposed 2 say was 1.27 volts gpu.
