- 22 Jun 2007
To change it is fairly easy if you have the correct equipment, IE a Windows or Nokia smartphone and the correct free software. Then it's a case of pressing one button and entering a pass code (0000) changing one setting, that's all.
As for the quality I think it's on a par with my Dell SP2309W for picture quality. (I am using DVI for both although one card is an ATI and the other an Nvidia)
Although if you are doing Graphics work will a 6bit TN panel be ok?
