GTX 460 vs PS3 Graphics
I was gonna say I'd be astonished if you can't to even better than a 460 for £1200, and Mr Krugga proves it! Good spec. You say it's primarily a gaming rig, though you want to do some audio recordings. Depending on what exactly you mean by 'some home audio recording', I wouldn't let that dictate the choice of components totally. Anything could do some audio recording to be honest, so if gaming is important, skew the balance of the budget more towards a decent GPU. For example you could take Mr Krugga's build there but go i5 4GB and get an even better GPU solution - like 460 SLI or ATI.
I own both the ps3 and xbox 360 and never use them now, the 460 will be a huge inprovement in modern games.
I think i read you have £1200 to spend? If so that should cover a GTX470
^ To the spec above, I think you have a few things very wrong.
1. Where is the PSU?
2. Where is the decent CPU cooler? That spec and you're expecting him to run on stock cooling?
3. Why have you included a sound card when presumably he'll be using HDMI which the 470 probably has audio over HDMI so has no need for it.
Intel Core i7 930 2.80GHz (Bloomfield) (Socket LGA1366) - OEM £229.99
OcUK Value GeForce GTX 470 1280MB GDDR5 PCI-Express Graphics Card £223.24
Asus P6X58D-E Intel X58 (Socket 1366) DDR3 Motherboard £149.99
Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC064MAG-1G1) £114.99
OCZ Gold 6GB (3x2GB) DDR3 PC3-10666C9 Low-Voltage Triple Channel (OCZ3G1333LV6GK) £99.99
Antec TruePower New Modular 650W Power Supply £84.99
Microsoft Windows 7 Home Premium 64-Bit - OEM (GFC-00599) £77.54
Coolermaster CM-690 II Lite Dominator Case - Black £62.99
Corsair H50-1 High-Performance CPU Watercooler (Socket LGA775/1156/1366/AM2/AM3) £59.98
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £44.99
Smsung SH-S223L/RSMN 22x DVD±RW SATA Lightscribe ReWriter (Beige/Black/Silver) - Retail £12.98
Sub Total : £988.66
Shipping : £10.50
VAT is being charged at 17.50% VAT : £174.85
Total : £1,174.01
Yeah. After 5 years of practice they get pretty damn good at coding for that crappy old hardware. Compare the release ps2 games to the newest ones, and it doesn't look like they're on the same console.
That's very true. Even the Super Nintendo was the same. some of the later games were very impressive but overshadowed by PS1 by this point. I'm not sure if you're saying that as a positive of negative for the consoles but to me it's a positive.
Well it's both really. It's a shame that console users are locked to old hardware without much chance of an upgrades, but on a plus side programmers getting more efficient is always a good thing considering the trend at the moment for bloated, inefficient software code.
I was shocked when I played uncharted 2 on my mates PS3, made me think differently about consoles as it looked really great imo. We just get console ports anyways nowadays. The advantage PC has is you can run 1080p resolutions and be near the screen, in the action, and for FPS its just unrivaled using mouse and KB.
