Looking to buy a new fragrance, but im unsure whether to just get the aftershave version and splash it on, or get the spray version. For my previous one I had a spray and it was fine, just wondering if the splash would be better?
Anyone used both for an extensive period and knows which one stays on you better? Or is it more or less the same thing?
It helps close the pores and doesn't have as long a lasting smell as EDT. EDT is not meant to be used on the face, instead the neck/wrists etc and the smell lasts longer. So it's more what you want to use it for. If it's for the fragrance alone then EDT Spray is best.
