If you are really serious then check them out:
http://www.rutlandtelecom.co.uk/
They can really rub BT's nose in the excrement
Agreed with the test socket. Plug it into that and see if the stats on that page show the downstream is improved at all?
Mine went from 1000 kbps to 2500 kbps on the test socket.
Will the phone still work if I do that?
Got a Speedtoucch ADSL filter box thing plugged into it.
Haha! You think that's awful?! Think yourself lucky!! This is my BROADBAND speeds since my neighbour had his landline installed the other day.
I also live in the sticks like you and used to get about 80kb/s to 120kb/s on a good day. I'm struggling to do anything on the net at the moment - i've even resorted to turning images over 100x100px off when browsing the majority of the time to try and make it bareable.![]()
MFrost, I kind of feel a little better know your speeds are beyond belief!
Anyway, have just plugged the router into the test socket and downloaded some rubbish from Steam. Same speeds.![]()
There's definitely something wrong with the stats, the router is probably reporting it wrong.
Have you updated the firmware on your modem? You should try the DGTeam firmware.
Ok chaps I have some news.
So, I plugged the ADSL filter box straight into the test socket yesterday as recommended.
I have just run speetest and the diagnostics on my router and have noticed some changes.
BEFORE (as previously posted above) -
AFTER (one day) -
So my download speed has gone up by over a meg, and my line attenuation has dropped significantly. I assume this is good, the download speed is!
I assume this may still improve further? I am now definitely going to buy an accelerator now as I don't want to go cutting wires and need to make the socket faceplate neat again as it is looking a little messy at the moment.
Thanks to all your responses, and for the other chaps who have got slow speeds. Try the test socket!![]()
Willing to try that bud.
Ok I am downloading the one for my router. How do I update the firware or is it all self explanatory when I run it?
Heh, read the Instructions from http://dgteam.ilbello.com/index.php?pid=16, under Web panel upgrade.
Make sure you're connected by a a wire as well.
Ok this is wierd. Downloaded the ZIP file which I of course, cannot upload to the router via the control panel. When I go into the file to unzip, there are 12 Disc Imaging Files.
*edit*
Ok I am being a nub but there are three .img files in English. Which one do I want?
*edit*
Ok worked this shizzle out. The 3 files are just versions of the driver so going to choose the one woth the highest number which is 026.
