I have another thread on the first or 2nd page.
Basically my Laptop failed to come out of hibernation and since then has been unable to boot properly. I can't access the recovery partition, well I can but it just hangs or takes forever, and booting from my OS disc also has the same problem.
I've been using something else I found from a boot disk utility beginning with 'N' (pritty sure I can't mention it here) which has been going all night and only repaired/scanned 40gb of the 500. Pritty sure it'll still be going when I get back from work and that the drive is in a pritty bad state.
I will try 'SpinRite' this evening.
Failing that I have some utilities that I could use to reformat the drive entirely however I have 3 partitions on there one of which has my music which I would quite like to save. I last backed this up at the beginning of June and haven't really added much since but it'd be good not to erase it if possible. I might have something which allows me to reformat a select partition. I would have done this via another PC but whenever I connect the 2.5" sata notebook drive (via a caddy) to any computer it just freezes up until I unplug it at which point the computer is then fine again.
Is it likely that it's just my C drive thats going to be borked or will all partitions on the disk be affected? Would a total reformat likely solve any of this or is the whole drive a write off?
Thanks for the replies.
Edit: It's a Toshiba drive and some reading on google shows there are few free utilities? I've a feeling it's totally naffed however I'd like to be sure before taking it back and potentially being charged to fix something I could have done myself.
