Hi guys,
I kept reading on various forums about a "kick" you should feel when the secondaries open at around 3500-4000rpm.
I can't say I was really noting any sort of kick. I'm aware of the common IMRC fault so decided to change the transistor and I also re-worked a couple of dry solder joints. If I rev under the bonnet I can see the actuator move when the revs build up, so it would appear the IMRC is working fine.
The car pulls to the red line. It feels slower than when I got it a couple weeks back but I guess I may just be getting used to it?
My friend has an RAC code reader so I will see if I can borrow this to double-check for errors.
So, how should the performance of the car be? Is this kick really subtle or more like Vtec?
