Quick, let's argue before the world implodes.
I wonder what the cost of running and maintaining an ST vs. a 182 would be?
Having the cam and aux belts done just once on the Clio takes you a significant way toward the ST modifications![]()
nope ph1 running a turbo, use to kill a gearbox on average once a month,if the driveshafts lasted long enough for the box to break that was![]()
Don't see many 172s running a turbo My friend has a SC'd and that made around 250 through the wheels! Seriously good fun
I don't believe for one second that unscheduled maintenance is 'nothing' on a 182, or even anywhere near as little as your typical modern Ford.
From what I've been reading, they are notorious for costing a fair bit to keep going. They certainly aren't known for their reliability or build quality.
Swapped the turbo out in the end and ran it for a short while on ITB's, got fed up with every other drivetrain component failing so got rid. Was hilarious ownership apart from the costs.
What kind of power was it making?I don't believe for one second that unscheduled maintenance is 'nothing' on a 182, or even anywhere near as little as your typical modern Ford.
Any car has the potential to be a money pit.
If it is something that'll keep you awake to the extent you imply you could always stick the couple of GRAND saved on buying the 182 over the ST in the bank for a rainy day fund.
Seriously, I don't think there is an augment out there that someone can logically explain why they'd pick a ST over a 182 (on paper at least)
230BHP when GDi took it to the RR after fitting the turbo.
Stop going on about the money saved buying a 182, it was discontinued in 2005 and a 2005 Fiesta ST is roughly the same money. You only save a couple of grand compared to buying a 2007 or newer Fiesta ST.
You can pick up an 182 on a 2005 plate for around £3.5/4K I cant see STs that cheap?
Thats fair enough, but you do get more for your money with an 182.
And I include myself in this statement - I myself will freely admit to favouring Fords, as a kid I always had a thing for cossies and after being taken for a blast in a group A escort when I was 11 the blue oval had a certain something
- Are they as fun as people make out?
http://www.pistonheads.com/sales/2346180.htm
http://www.pistonheads.com/sales/2335953.htm
http://www.pistonheads.com/sales/2214564.htm
Not saying these are any good, but it can be done.
And all of those cars are lacking the vital mountune kit that even the ST supporters admit the Fiesta needs to be in the same ball park as the 182...
