- 16 Mar 2011
I have a really strange problem that only started a couple of weeks ago.
When I first turn on my computer in the morning (when it is at it's coldest) the 5870 makes a really loud noise - as if there is something wrong with the fan. However after around 4 or 5 minutes it stops completely.
It's really strange because the temps are fine (33'C as it has just been switched on), and the fan control in CCC still works - i can adjust the fan speed, but even if i don't do anything with it it only reports a 21% fan speed (when the noise is happening) so it's not like it is trying to go too fast.
When the noise stops it doesn't come back till the next morning, so it seems like it is due to the cold temperature.
I know the noise is coming from the 5870 because i recently built a new computer and the 5870 is the only thing i kept from the old PC (it made the same noise in that computer too).
The card is over a year old now so i'm not sure what i'd have to do if it died but like i say - it still works perfectly and the noise stops after 5 minutes.. and the card keeps the GPU below 80'C under heaving gaming load.
My reason for posting is because i know noises like this are normally not good - any help would be appreciated.
Thanks.
Thanks.
