- 1 Dec 2009
- Staffordshire
gentle typhoon
Ok.
I've got 2 Akasa vipers sat in the house (delivered today), but I'm going to try the stock fans with the PWM first, to see what difference it makes.
Might also try the H70 in one of the top fan mounts, drawing air in as I feel drawing the air in from the back of the case to be a bit of a strange move, given the gpu is pumping out hot air and the case is around 6 inches from a wall = sucking all the hot air being pumped out by the components.
I have two H60 running in machines and 1 H70 all set to silent in ASUS setups,
The CPU are overclocked and the temps are fine
The only Noise I get is when the Pc,s boot up then go very quiet
D'oh, yes indeed.
Looks like I'm going to have to go straight with the Vipers.
@psychas ... are you running with a PWM splitter and using the BIOS to ramp up speed as needed?
What speed does Q-Fan set the fans to on the Silent profile? I'm assuming the silent profile doesn't speed the rpm up slightly at all? hence silent. As I have mine on manual settings, if it reached 40c it'll up the rpm to my specific % duty mode.
I wish I could pick any percentage on manual. I really detest what Asus thinks you'll need. Not giving me full control. I'm also sick of them always having values of 10's. I want to punch in my own numbers!
Manual the lowest I can pick is 50% fan speed, which is about 1200-1300rpm, I've set it to 60% duty when it reaches 40c which bumps it to 1400-1500rpm.
Im looking at getting two of these: http://www.overclockers.co.uk/showproduct.php?prodid=FG-061-AK&groupid=701&catid=57&subcat=4
To stick on my alc eco. I'll be intersted to see what the temps on the apache come to. BTW, other than colour, whats the diff. between the above and apache blacks?
