- 2 Dec 2006
with £1200 you can get a phenomenal gaming rig that will last you ages.
to fit it in the £1200 budget i had to get a much cheaper case. i picked the HAF912 because its a great case, and its kinda similar to the HAF X
YOUR BASKET
2 x Asus ATI Radeon HD 6950 OC 2048MB GDDR5 PCI-Express Graphics Card £209.99
1 x Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £161.99
1 x MSI P67A-GD53 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) ** B3 REVISION ** £109.99
1 x Crucial RealSSD M4 64GB 2.5" SATA 6Gb/s Solid State Hard Drive £99.98
1 x Pioneer BDR-205 12x BluRay RW / 16x DVD±RW Drive - Black (OEM) £99.98
1 x Antec TruePower New Modular 750W Power Supply £89.99
1 x Coolermaster HAF 912 Plus Case - Black £55.98
1 x Corsair Hydro H50-1 High-Performance CPU Watercooler (Socket LGA775/1155/1156/1366/AM2/AM3) £54.98
1 x Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache - OEM (ST31000528AS) £42.98
1 x Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £35.99
Total : £1,171.85 (includes shipping : FREE).
not quite sure how ive got free shipping, but it would probably be around £20-£25 for this lot
Why would you buy the Antec 750w true power? That makes no sense at the price it's being sold at the xfx core 850w is substantially better and cheaper. Antec psu's are nothing special unless on a tight budget.
480GTX > 6950. Granted the 6950 is less powerhungry though so that does make it desirable when doing sli/crossfire.
Personally would stretch up to the MSI P67A-GD65. I run one and they are good boards.
As i've stated before 64gb ssd really does not go far at all. Can't see the point in getting an ssd which pretty much just lets you boot up 30 seconds faster as put the OS and 3/4 games on it and it's full. Or 3 games and some apps like chrome etc. Might not even hold that.
As stated before, personally would stick to air cooling for a sandy bridge as you just don't need the water cooling nor the extra hassle.
At 1.2k personally I'd get 8gb just because it's hardly much more and you just might as well have it. In my opinion, obviously not a necessity.
. It's not that big of a difference else where. Having said that the P67A-GD53 is still a great board, MSI have done really well this round of mobo's. I just rather spend the bit extra personally, the P67A-GD53 doesn't have as good heat sinks etc. Not really a biggy though.
