Good Cheap Server - HP Proliant Microserver 4 BAY - OWNERS THREAD
4 Dec 2002
Bourne, Lincs
Bought 1 of these for the optical drive bay so i can have 6 harddrives enclosed within the system.
Where does the 6th drive go?
29 Dec 2010
4 Cold Swap bays
1 ODD SATA Port on M'board
1 ESata Port (wire run in from back, custom BIOS).
Perhaps, if you're stacking SSDs or cool 2.5" HDDs into the ODD bay, you could use a USB hub, ideally finding one which could take 12v power from a Molex connector. Or you could disassemble 8+ 2.5" USB->SATA enclosures - they might all fit.
13 Aug 2010
UK
That would be horribly slow.
Just use a SATA pci-e add-in card.
26 Jan 2011
I was hoping to use it as a tool to take my SBS 2008 exam. For that I need to be able to run 1x SBS2008 and 1x Vista x64 VM.
I'm currently running 2008 Enterprise, but was considering putting 8GB of ram in and trying to get an SBS2008 with a vista VM in Hyper V.
Cheers,
G
/edit I currently have 4GB of ram and 2008 Enterprise runs everything I want to do in terms of FTP server, media server and teamspeak server. I will not really want to do much more with it than that.
I've partitioned the HDD into 3 chunks, one 148GB and two 75GB, I have enterprise on the 148GB one at the moment.
I tried to install the SBS 2008 as a VM, but it wouldn't install, it just said it needs a minimum of 4GB ram to install, so I thought I'd check if it will run it before I fork out for the 8GB of RAM. My SBS2008 book says that it needs a minimum of 4GB ram and a dual core 1.6 cpu. But I am hoping it might just scrape by considering it's never going to be under load since it's only going to be for my exam and never in production.
I had so many problems getting it to work as a media centre i ditched it and went with Windows 7.
Had to install BDA drivers etc.
Not sure how different SBS is to R2.
23 Mar 2011
i'm thinking about buying one of these instead of a nas and installing whs or windows server 2008 and putting 2x 2tb drives. couple of questions: Can this handle streaming all my movies to a couple of xbmc xboxes a htpc and a wdtv. Also would this be pointless as i currently have a dell poweredge sc1425, but it uses a lot of power to be on 24/7 and is very noisy.
13 Aug 2010
UK
Don't know about your first point, but the microservers are quiet and efficient enough to be left on all the time, so that answers that one!
8 Jun 2005
I'm assuming that you won't be streaming to them at the same time?
Mine quite happily streams and transcodes mkv files to my ps3 and laptop, although the ps3 seemed to struggle with a 17gb one the other night, ended up plugging a laptop in instead and streaming to that. Will try again now I have 8GB of ram in the server and report back.
/edit didn't help with 8GB
28 Sep 2003
Leamington Spa
So my Ubuntu system kept freezing/being slugglish and killing off sabnzbd/sickbeard randomly. I've turned off granola and the problems seem to have gone away (also, why was granola using 100's of MB of ram??) anyone had any similar issues?
18 Oct 2002
4 Cold Swap bays
Need the custom bios to run this rear? why would they even include it physically then?
Mine works neither with or without the custom firmware - and I do see the 6 ports in the bios :/
14 Nov 2002
West Midlands
Anyone know how to enable the 5/6 ahci port as external/removable so it's listed in Safely Remove Hardware in the tray?
I'm using WHS2011 with the modified bios with all 6 ports seen as ahci and a tray in the odd slot.
WHS2011 sees a drive inserted in the tray correctly but I'd like to safely remove the drive using the Safely Remove Hardware tray item.
I've tried adding a registry entry "TreatAsInternalPort" as 0x0 under
HKLM\SYSTEM\CurrentControlSet\Services\msahci\Controller0\Channel<N>
to no avail. It doesn't bring up the Safely Remove Hardware list.
2 Nov 2007
Use http://mt-naka.com/hotswap/index_enu.htm .
14 Nov 2002
West Midlands
Thanks for the pointer.
After further thought I've managed to sort it using "Safely Remove Hardware" without using that utility.
In bios under Chipset / SouthBridge Configuration / SB Sata Configuration
Disable "SATA IDE Combined Mode" - sets port 5 and 6 to use AHCI
Enable "SATA ESP on all PORT" - sets all ports to be external SATA ports
then set ports 1 - 4 to be internal via the registry (unless you want to hot swap all the drives)
reg.exe add "HKLM\SYSTEM\CurrentControlSet\Services\msahci\Controller0\Channel0" /f /v TreatAsInternalPort /t REG_DWORD /d 0x00000001
reg.exe add "HKLM\SYSTEM\CurrentControlSet\Services\msahci\Controller0\Channel1" /f /v TreatAsInternalPort /t REG_DWORD /d 0x00000001
reg.exe add "HKLM\SYSTEM\CurrentControlSet\Services\msahci\Controller0\Channel2" /f /v TreatAsInternalPort /t REG_DWORD /d 0x00000001
reg.exe add "HKLM\SYSTEM\CurrentControlSet\Services\msahci\Controller0\Channel3" /f /v TreatAsInternalPort /t REG_DWORD /d 0x00000001
Now inserting a drive in ports 5 and 6 cause "Safely Remove Hardware" to be available and it all works :)
9 Sep 2006
People who have added an extra drive in the optical bay, what sort of mounting system have you used ?
I have a few 5.25" to 3.5" brackets but decided to go with something that allows front access to the drive, this isn't working so well...
The one I've picked up doesn't work very well with the mounting screws being in grooves as the bay relies on the side brackets being firmly screwed in for the vibration damping to work, as it is the screws on the left hand side kind of flop out because of the slack allowed by the vibration damping.
Also I was trying to avoid a bay with a 40mm fan in it....
14 Nov 2002
West Midlands
I used an Icy Box IB-168SK-B. The rubber mounts on it are a bit of a pain the Microserver as they allow the side screws to come out of the rails so I glued a plastic support under each of the four corners to prevent the side angle brackets from coming out of the rails.
