Permabanned
I don't have onboard graphics, but realistically speaking, if I can't even flash from DOS (by which I mean proper DOS, as in the OS that was obsoleted by Windows 95, not a Command Prompt window) I'm not sure how safe mode is going to help.
I seen somewhere that u can flash back in bios with USB stick.I was going to do it before I flashed mine back which was just total luck.
Will send you link when i get home, I think i have it bookmarked somewhere.
If that doesent work Can you use a friends computer with onboard graphics?
I thought i had bricked mine and was minutes away from losing the rag, I didn't have a switch for my 1 gb6950 so was pretty stupid of me to attempt to flash in the first place.
I couldn't boot into windows after flash went bad and couldn't get into windows without bsod.
I ran into safe mode and the computer booted into windows with it's on board graphics, unistalled the drivers and rebooted( the computer then booted using on board graphics)and re flashed.
I have tried this a couple times to make sure it wasn't a fluke.
