Gigabyte 480 SE/SOC - Post your overclock!
16 Feb 2010
Malvern, England
Not a GB one but my reference Asus one runs at:
820
1900
On stock volts which is 1.064v
I have gotten higher I think it was 860/2100 on stock volts but I got little artifacts in Heaven benchmark but not in any of my games though :S So I just changed it to SOC clocks to stay happy.
11 Mar 2011
some nice overclocks there guys, anyone on water?
i have a 570 but a bit worried about overclocking as their rep is that they can't handle it like the 480's and 580's
1 Jun 2004
My SOC is stable at 800mhz which is 20mhz lower than it should be :(. It's also running very hot 100 degrees during witcher 2 and 99 degrees in Kombustor. Temperatures seem very hot. What other temperatures are everyone else getting?
16 Feb 2010
Malvern, England
Witcher 2 is very GPU intensive.
My Reference GTX480 runs at 83C at 77% fan on Witcher 2.
80-81C for Crysis 1 and 2 with 70% fan.
77C for Source games at 62-65% fan.
Getting water cooling soon so the temps and noise wont be an issue and I use headphones anyway.
1 Mar 2007
Those temps sound high for in game. With my SOC at factory overclocked settings in a HAF-X, in games I get around 80C at about 60% fan speed. Furmark is pushing temps up to just under 90C after a couple of minutes with a 100% fan speed.
28 Sep 2007
Milton Keynes
480 SoC here.
stock was 820/1900 100% stable @ 1.035.
Now 870/2000 @ 1.080v.
Had it up to 900/2100 with 1.100v, but made no perceivable difference in games due to my CPU holding it back.
Temps very rarely go above 80oc except in that OCCT thingy.... ( avoid ).
Heaven ...1235 cannot get anymore as CPU is a bit old now.
27 Jan 2010
Manchester
Caporegime
8 Nov 2008
480 SOC.
Stock : 820 / 1900 stable, 1.063 volts.
I've been having a tinker with it, still on stock volts though, while playing Stalker COP complete.
Core : 865 - 870 / 1960 ish - that's about the limit it seems, so more volts needed.
27 Jan 2010
Manchester
So far I am on
core clock- 791,
memory- 1921
... still continue overclocking, taking one step at the time! Stock volts, temp goes up to 77C!
20 Aug 2006
480 SOC:
Stock 820/1900 - 1.038V - unstable (in my system)
Current stable settings: 780/1950 - 1.063V
disappointed but not the endofthe world
someone asked about Witcher 2 temps - get 79-80C even after a few hours. JC2 - same sort of temps- perfectly acceptable really. OCCT gets to upper 90s - but card is still stable
