Has anyone killed a piece of hardware due to static...
I've killed individual components before they made it to the PCB. Once on the PCB, static tends to be less of a problem as it dissipates accross the board rather than one component.
Bought a antistatic mat years ago & never used it on any builds so far. Actualy i just remembered its here. :p
A few years ago (about 10:p), I think i killed a fairly good soundcard due to static :(
Since then I've been pretty careful with AS precautions, I actually (finally) bought an AS plug the other week so I can just plug my mat and strap into it, and then into any available socket :)
Having said that normally I only go full AS if building/rebuilding (the mat is very handy for the motherboard/fitting cpu's/coolers etc), and if just swapping something like a hard drive I don't even bother with the strap.
Havent killed anything with static yet and I have never used anti-static wrist strap or mat, cleaned PCs with vacuum cleaner (stopped now, just use soft brush). What I usually do is just switch off PC completely, flip the switch on PSU, unplug it from mains then press power button few times. This technique seems to work fine for the past few years :)
Haven't killed anything with static afaik, but today I had a static shock as I touched PC case, holding a CPU in my other hand.. luckily it still works
Around 10 years ago the general advice I came across was that an anti static strap was a must especially when handling motherboard.
But neither me nor anyone I know have killed any componants when building or upgrading - hope I haven't jinxed myself by saying that ;)
"ESD immediately destroys sensitive devices in only 10% of most ESD
incidents. It degrades performance in the remaining 90%. Only a quarter of the
voltage required to destroy the component is needed to degrade its
p e r f o rm a n c e"
This is the thing, chances are it'll work fine for a while if you've caused damage.
Good statement. It's good to know there are some people who know what they are talking about when it comes to static. I used to be in the "I never damaged a thing with static" category until I learned a little about it. Then I realised that I was in fact probably causing lots of damage. I just hadn't realised it.
Where I work the carpet is always generating static, so everything I touch (including people Mwuahaha) causes a static shock. I dismantled and rebuilt a PC here the other day without any issue, and all I did was earth myself on the desk every 5 mins by touching it giving myself a shock lol
That wouldn't be an issue as the the static is not earthing via the GPU. It's only if the potential difference between the two is enough to get static to jumop from you to the component that it would be a problem.
I think...
