Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
We've all had arguments with our mates down the pub etc.. 100 % sure we're correct, only then to be prooved wrong later.
This has never happened to me?
[TW]Fox;19473082 said:I too find it helps to translate my forum experiences into fictional tales about the outside world. It's a great coping mechanism.
How do you find the fact that a postcode is A rated etc..etc..?
Mine is SA5 4NP.
Thanks.
Why do people never seem to take advise / constructive criticism well in here? I love it, much entertainment!
Voluntary excess can only be included if you go with comprehensive - and then it works out more expensive than TPFT with excess. SDP also works out cheaper, and I don't think the fact that I only put alarm and not immobiliser is the difference.
Voluntary excess can only be included if you go with comprehensive - and then it works out more expensive than TPFT with excess. SDP also works out cheaper, and I don't think the fact that I only put alarm and not immobiliser is the difference. Adding named drivers onto it also brings it down, so you've obviously changed things somewhere.
Voluntary excess can only be included if you go with comprehensive - and then it works out more expensive than TPFT even with the excess. SDP also works out cheaper, and I don't think the fact that I only put alarm and not immobiliser is the difference. Adding named drivers onto it also brings it down, so you've obviously changed things somewhere.
Fine, pay your 3 grand insurance and be happy, I seriously cannot be arsed trying to help you any more.
ahah priceless? I point out that excess can only be used with comprehensive and that named drivers lower insurance and you come back with a comment like that? Farcicle.
[TW]Fox;19473238 said:Why would you insure a 4 grand car TPFT?
Do a quote directly on the Elephant/Bell/Admiral website.
Listen son i got to say it again, what did you want here again?
Cos i really want 3 inches extra of willy and immunity from income tax, but its just not happening.
I wouldn't, but I put that in simply to get the lowest quote i could - which is still nowhere near the 1500 quid people were throwing about before I posted the screenshots.
You've never ever been mistaken ?
Crikey your arrogance is outstanding.
Ah and a pretender to the perfect crown appears.
