I did my CBT about 18 months ago, rode around on my CBR125 for a bit then did my test and got an SV650s last November.
Whilst I like the SV650s, part of me would like something a bit more upmarket (ie had "proper" brakes/suspension and maybe even posh stuff like a fuel gauge
From doing a bit of research I've narrowed it down to 2 bikes, the Kawasaki ZX6r and the Triumph Daytona 675. Both bikes seem to get a decent upgrade in 2009 so I'd be looking for a lateish model. The main difference between the two seems to be down to the engine, do I go for the IL4 or the triple?
Has anyone got any experience of both?
)From doing a bit of research I've narrowed it down to 2 bikes, the Kawasaki ZX6r and the Triumph Daytona 675. Both bikes seem to get a decent upgrade in 2009 so I'd be looking for a lateish model. The main difference between the two seems to be down to the engine, do I go for the IL4 or the triple?
you will know instantly what you prefer, and going from a twin you may find the howl of a IL4 seems to be faster but you will also notice the Triple pulls everywhere, your still going stupidly fast but you wont notice the rush as much as you do when an IL4 gets into its rev range
I found the triple had much more usable power, you could be pootling along in third and wack open the throttle and your doing illegal speeds in seconds before even needing to think about changing gear, it has so much usable revs! as long as you don't mind making a lot of noise
