TODAY ONLY 06/08/2011 - CRUCIAL BALLISTIX SPORT 8GB & OCZ AGILITY 3 60GB SSD!!
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Today Only we have 50 units of the lightning fast OCZ Agility3 60GB SSD for only £83.98 inc VAT. Enjoy read speeds of over 500MB/s and transform the performance of your system.
We also have 50 units of Crucial Ballistix Sport 8GB 1600MHz C10 Memory kit for only £41.99 inc VAT. Expand your system memory to 8GB and enjoy ultra responsive computing.
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive (AGT3-25SAT3-60G) @ £83.98 inc VAT
As the third generation of the Agility Series, OCZ Agility 3 Solid State Drives are designed and built to unleash the full potential of the 6Gbps SATA3 interface. The OCZ Agility 3 pushes the limits in both sequential and random data transfer rates, significantly improving your gaming, multimedia, and overall computing experience over traditional mechanical hard drives. In addition to maximized productivity, a Agility 3 upgrade makes a hard drive equipped notebook more portable than ever with superior durability and reduced power consumption.
Using the latest break through controller and flash technology, Agility 3 SSDs workin perfect harmony with next generation platforms and operating systems to deliver the industry’s best storage solution.
- Capacity: 60GB
- Controller: SandForce SF-2281
- Maximum Read: 525MB/sec
- Maximum Write: 475MB/sec
- Max I/O Per Second (IOPS): 50,000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was £89.99 Inc. VAT
Only £83.93 inc VAT.
ORDER NOW
Crucial Ballistix Sport 8GB (2x4GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (BL2KIT51264BA160A) @ £41.99 inc VAT
Overclockers UK brings you one of the most notable names in system memory today.
These high performance modules are engineered to deliver the fastest, most reliable memory for gaming and performance enthusiasts. Upgrading has never been this easy!
If you‘re new to performance memory and like what Ballistix has to offer, the Crucial Ballistix Sport Series is a great place to start. This line was created for mainstream users and general enthusiasts. They feature heat spreaders for thermal performance along with standard timings and voltages, making this reliable, quality module ideal for maximum stability and compatibility.
This memory allows you to plug it into your system and get back in the action for an affordable and easy upgrade, ideal for any Intel Sandybridge or AMD AM3 based system.
- PC3-12800 1600MHz CAS 10-10-10-28
- Designed for Entry-Level & Mainstream Users
- Integrated Heat Spreaders
- 1.5v VDIMM
- Dual Channel Memory Kit, Ideal for any Intel Sandybridge or AMD AM3 based system
- Limited Lifetime Warranty
Was £53.99 Inc. VAT
Only £41.99 inc VAT.
ORDER NOW
'gaming and performance enthusiasts'
'mainstream users and general enthusiasts'
'Designed for Entry-Level & Mainstream Users'
All of the above are attributed to this memory, which is true or are they all true.:confused::D
Great price by the way!:)
