So you want to make yourself a sandwich, you walk into the kitchen, over to the fridge get out your butter and cheese or what ever, put them on the work surface, go to you cutlery draw and get out a knife, then go get a plate, then get the bread out. Normal procedure right?
Or do you do what I do and try and maximize your work rate and efficency in preparing the sandwich. So I walk into the kitchen and I'll instantly go through in my head everything I need and plot what I should do to make things easier for myself, so as I walk in to go to the fridge (that's sy the far end of the kitchen) I'll walk past the cupboard with the bread in, I'll flick that open, walk past the cutlery draw and cupboard with the plates in I'll open them. All in one swift and continuous movement, get to the fridge take out what I need. Start to walk bs k and slide them along the top towards the cutting board grab a plate and a knife, close both cupboard and draw as I turn away usually with my foot and other hand so I'm doing things as quickly as I can make them.
I'be noticed that I've started to do this a lot more now, especially when I'm in the kitchen when several different things need doing and usuay if I forget to do something or get something out, having to go back and get them then I get annoyed at myself.
So does anyone else do something similar, or just me?
