- 26 Apr 2004
- Milton Keynes
The artifacts appears to be related to the fact mpc-hc doesn't appear to detect hi10 properly and seemingly tries to decode it as per a normal 8bit video (as highlighted in my testing by the fact it still lists DXVA active which it doesn't if you try a non compatible file)
That is why you get artifacts, which can go from not too bad to horrendous looking, dependant on the videos use of hi10.
The hardware ASIC on the current gpus is not compatible with 10bit decoding so until this changes, distorted decoding at best is all that can be produced without using a software decoding solution.
