Today only we have the best price in the UK on Intel Core i7-2600K 3.40GHz and you can take a snapshot of this purchase with the BenQ c1230 camera at a bargain too!!
BenQ C1230 12MP Compact Digital Camera - Silver/Pink @ £23.99 inc VAT
The BenQ C1230 is ideal for anyone who just wants a simple point and click compact digital camera that is easy to use and takes good quality photos. Its ideal for children, students and even those looking to get into photography. Robust and small enough to take everywhere with you, so you never miss the opportunity to take a photo and at a cost where if the kids do break it or drop it then its not cost the earth, making this camera an ideal gift for Birthdays, Christmas, Valentines Day etc.
With smart scene mode automatically detects 8 different types of scenes and chooses an appropriate one out of the following 8 scene modes: Landscape, Portrait, Backlight, Backlight Portrait, Night Scene, Night Portrait, Macro, and Sunset. All you have to do is press the shutter and the Auto Scene Mode will do the rest for you.
With 5cm Macro, it will automatically scan and switch to the Macro mode when you are taking close-up photos of flowers or small objects. So every photo is in focus.
Want to take a good photo when there are just two of you? Love Portrait mode will take a shot when detecting at least two faces.
Blink Detector alerts you when a subject has blinked, allowing the shot to be retaken immediately or saved according to your preference.
Specification:-
- Sensor SONY 12 Mega Pixels, 1 / 2.3 inch CCD
- Picture Resolution 12M / 3:2 / 8M / 5M/ 3M / HD 16:9 / VGA
- Lens f = 6.2 ( W ) ~ 18.6 ( T ) mm
- F= 3.0 (W) ~ 5.6 (T) (f = 34.6~103.8mm, 35mm equivalent)
- Zoom Optical: 3X
- Digital: Up to 5X (Preview) / Up to 12X (Playback)
- Focus Range Normal: W=80cm ~ Infinity
- Macro: W=5cm ~ 100cm
- Shutter Speed 1/2000 ~ 1 sec. (Fireworks 2 sec.; Manual 15 sec.; Night Scene 8 sec.)
- Display Size 2.7" LCD
- Display Resolution 230,000 pixels
- ISO Equivalent Auto / 50 / 100 / 200 / 400 / 800 / 1600 / 3200 (3M or lower) / 6400 (VGA and HD 16:9 only)
- White Balance Manual (6 modes in manual selection : Daylight / Cloudy / Tungsten / Fluorescent H / Fluorescent L / Manual)
- Flash Auto Flash, Auto Anti Red-eye, Force On, Slow Sync, Forced Off
- Self-Timer 2 sec. / 10 sec. / Double / Burst
- Movie Mode 720 x 400 (16:9) / 640 x 480 / 320 x 240 / Web sharing
- 30 fps, Continuous recording with sound
- Storage Built-in Approx. 21.1MB
- 4GB SD compatible / 32GB SDHC card compatible
- Interface Digital output: USB 2.0 compatible
- Audio / Video output (NTSC/PAL)
- PictBridge compatible
- Battery AA Battery x 2
- CIPA Approx 200 base on bundled batteries
- Dimensions (W x H x D) 92.0 x 60.5 x 23.8 mm
- Weight 120 g (without battery & SD card)
- Accessories (Standard) USB Cable / Software & UM CD / Quick Guide / Hand Strap / Pouch /AA Battery x 2
- Product Color: Silver / Pink
- 2yr Warranty
Only £23.99 inc VAT.
ORDER NOW
Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM @ £233.99 inc VAT
Intel's new Sandybridge based CPU's is a complete new refresh that requires new socket LGA1155 mainboards. This new platform uses less power and has vastly superior integrated graphics. The HD2000 graphics is capable of all multimedia task featuring DirectX 10.1 runtime making them ideal for gamers too. The K series edition processors are unlocked on the multiplier allowing overclocking and also feature HD3000 onboard graphics which feature twice the horsepower of the HD2000 making them ideal for gamers and have support for 3D Gaming. The new Sandybridge K series processors also feature immense overclocking as well.
- Lithography Process: 32 nm
- Cores: 4
- Threads: 8
- Frequency: 3.40 GHz (Turbo Mode 3.80GHz)
- Integrated HD 3000 (12 EUs) Graphics
- Integrated Graphics Frequency: 850MHz (1350MHz Turbo)
- Cache: 8 MB shared L3
- Memory Controller: Dual channel DDR3 800/1066/1333/1600 MHz
- TDP: 95W
- Socket: LGA1155
- Compatible with Socket 1156 heatsinks
- 1yr Warranty
***OVERCLOCKING GUIDELINES***
- Do not exceed 1.35-1.38v core voltage, doing so could limit lifespan of the CPU
- Do not overclock with BCLK, again doing so could limit lifespan of the CPU
- Recommended memory voltage is 1.50v, so make sure to run your memory at 1.50v, higher could limit lifespan of the CPU
- These recommendations come from OcUK and Intel, your warranty is un-affected but we highly recommend you adhere to the above to make sure your CPU lifespan is un-affected
- All Sandybridge CPU's worldwide should be run at the above or lower voltages, no higher!
Only £233.99 inc VAT.
ORDER NOW
Specification:-
- Zoom Optical: 3X
- 2yr Warranty
ORDER NOW
- Cores: 4
- Threads: 8
- TDP: 95W
- Socket: LGA1155
- 1yr Warranty
ORDER NOW
