Hard Drive Pricing going up at an alarming rate!!!!
Try actually clicking on the LINK. It may show £49.99 but when you are re-directed to the site, it says the best part of £70.
Another says £55.76 (popular retailer) but when re-directed to the site, it says £107.86
If I could get them for what you quoted, I would buy a few and make a killing!
Moral here, check your facts.
Frustration free packaging...
On a side note, I bought a little load of 2TB drives in anticipation last week at £80 a pop. Today the same drives are £130.
Also worth noting is that a competitor sells a desktop PC with a Pentium Dual Core CPU, 4GB of ram and a 1TB hd for £190. The cheapest 1TB HD the same competitor sells is £100.
Well my nice shiny usb 3 2tb drives at £59.99 a pop arrived today. I could have just bought a crap load and hoarded, then sold them on at an increased cost, instead I got two then put the deal on a well known deals website so others could save some money.
new hd's are not slow. 4tb seagate is 180mbps r/w. i use a small ssd for boot drive.
New hdd's are VERY slow, every single part of "ssd" performance, and what makes ssd's seem fast, booting, application opening, ultra responsiveness is from, latency and 4kb read/writes, a new 4tb Seagate is still in the 13-18ms latency range, vs WELL below 1ns for SSD's, and in the range of 0.5-1.5 4kb random read/writes, where the latest ssd's will be along the lines of 30-40mb's read's and even higher writes.
Sequential speeds of ssd's even up to 2 years ago wasn't very impressive vs hdd's, 130-140mb's sequential speeds on hdd's vs 90mb's on the first ssd's, 170mb's for a couple years after that wasn't impressive, it was all in the latency and random read/write performance, HDD's are magnitudes behind in those key area's and haven't moved on at all, SSD's have extended the lead in the ultra slow area's and sequential read/writes have now trebled over HDD's, while years ago they weren't even faster, but slower in that area. The gap is extending by a pretty big margin each and every year now.
From http://www.storagereview.com/seagate_4tb_barracuda_xt_first_thoughts_review
We measured sequential file transfer speeds at 140.2 MB/s read and 133.8 MB/s write using 2MB transfers in IOMeter. Those speeds slowed to 48.3 MB/s read and 40.2 MB/s write with 2MB random transfers.
Moving to 4K random transfers, we measured speeds of 45 IOPS read 94 IOPS write or 0.176 MB/s and 0.366 MB/s respectively. These values came up shy of what we measured on the 3TB XT, although its comparing a full production model to an unannounced and otherwise unreleased drive.
Using CrystalDiskMark to measure performance of the inside versus the outside edge of the platters, we found the speed to be a bit higher than what IOMeter saw on the top end. This could be explained by IOMeter looking at a broader section of the drive, where our forced inner/outer test only looks at the outermost or innermost edges for best or worst case performance.
On the outer tracks of the 4TB Barracuda XT we found speeds measuring 188.6 MB/s read and 187.5 MB/s write. These values slowed to just 88.82 MB/s read and 88.71 MB/s write on the inner portion of the drive.
Performance is very poor, random performance hasn't increased in really, 7-8 years, sequential has gone up marginally, and the inner tracks haven't gone up much at all, average performance is up a very small amount.
SSD's can do sequential 550mb/s reads and 450mb/s writes across the entire drive, with no slow down, random 2mb performance is basically the same, where hdd's drop to 1/4 of the performance if that, 4kb performance on hdd's drops to sub 1mb/s, while ssd's only drop to 30mb's read's, 70-80kb's writes. With higher queue depth on ssd's you can dramatically increase random 4kb read/write back towards top performance while on hdd's it makes next to no difference.
They do cost a lot, obviously, but you get massively better performance, you're talking about 100 times the random read/write performance, actually in writes its more like 200 times the performance, 4 times the sequential performance, instant access, etc, etc. Its also far to say cheaper ssd's and smaller ssd's drop performance significantly vs 240gb models, however, even the slowest 60gb ssd drives still absolutely blow away HDD performance.
Suddenly SSD's (Sexually Sent Diseases?! :confused:) don't look so expensive!!
It's probably been mentioned already but why the huge increase? Is it really to do with flooding in Thailand :confused:
Even with the increased pricing our demand is un-changed, infact its increasing.
If this is the case, do you think this will have any affect on the price coming down again once the situation is over? I wonder when manufacturers realise people are still happy paying the raised prices (increasingly happy to do so you say :() - will this stop the prices coming back down again, or at least make them come down a _lot_ slower?
Also, do you have any indication of whether the situation might also start to affect the SSD market and would it be worth looking to buy these sooner rather than later?
Guess i have you to thank then, i have 4 2TB Hitachi's coming from the same place. Bought for £54.99.
Who knows, for us its about time ASP's increased as drives, memory etc. has been way to cheap for far too long, getting to the point where the manufacturers making far less.
So though prices will definetely come down, though no doubt next year now, the question is will they come back down to what they were, only time will tell.
In regards to other hardware, well it does appear SSD, optical is starting to move upwards slowely. One can expect laptops to move as well and of course full systems due to having hard drives in them.
Memory at present is stable but thats still not had his usual increase apart from a little one last month, so that is unknown.
Everything else seems rather stable but there is nothing to say a memory factory won't explode next week.
Good thing I already got two 1 Tb Sammy F3s for £60 each, and two 2 Tb F4s for £69 each :)
They went even cheaper than that recently.
Well this sucks. I was looking to pick up a couple of 1tb WD Blacks but at £145.99 i think i'm going to wait.
Did notice that the prices on a very big US PC store are considerably lower. A 1tb Black is currently $139.99 (£87).
Always seems like when prices increase, we Brits take a much larger hit than anywhere else. :mad:
Ordered an 2TB 5400 RPM HDD today from a big retailer online, needed it pretty desperate to complete my system. For £70 quite a bargain especially at this time :).
