I'm downloading the 472mb patch nowWhat driver should I be using, and what CAP? I have a single 5830 and I have never used a cap.
CAP's are only for crossfire, you dont need them
What driver do you recommend, I think there has been a few for BF?Ahh OK cheersWhat driver do you recommend, I think there has been a few for BF?
I'm currently waiting for it to download. I played the beta on the official 11.9's and didnt seem to have any major problems, so i'm sticking with them for nowWhile I was trying to re-map my joystick to this game, I got kicked out from server.
It happened several times.
Did any of you experience similar situation?
Also can re-mapping be only done while in-game? No alternative?
I haven't played BF3 yetI'm currently waiting for it to download. I played the beta on the official 11.9's and didnt seem to have any major problems, so i'm sticking with them for now
feel free to add me, username LoCk3H
do i have to change my system time aswell as the IP?![]()
No, just use the proxy.
Before I jump in - this is incorrect is it not?
I'm 99.99% sure CAPs are for any card.
To be honest mate, Im perfectly happy with a single 6870. Will probably use the money to upgrade to high-end 7000 series if necessary.![]()
I have a 6850 and same thing for me. Was running it on Ultra fine but then on some maps it stutters randomly. Game freezes for a 2nd or so, really annoying! Hopefully ATI will release drivers soon. Apparently theres CAP drivers available that fix the stuttering, not sure what cap means? Beta drivers?
