Hi there
Time for some monitor deals:-
Iiyama ProLite E2208HDD 22" Widescreen LCD Monitor - Black @ £99.98 inc VAT
The ProLite E2208HDD Widescreen LCD features true High Definition, 16:9, 1920 x 1080 pixels as its native resolution. Impressive colour reproduction is achieved with a typical contrast ratio of 1000:1 with the User Option to enhance further with Advanced Contrast Ratio enabled for 10000:1. 'Opticolour' automatically makes calibrated adjustments to Contrast, Brightness and Colour Balance to suit your application needs. Analogue and Digital inputs guarantees flexible connectivity.
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000:1
- Brightness: 300cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 516.5mm x 386.0mm x 193.0mm
- Weight: 4.2kg
- Warranty: 3 Years On-Site
Was [£114.99] Inc. VAT
Only £99.99 inc VAT.
ORDER NOW
Hazro HZ27WD 10-Bit 27" LED Widescreen Professional Monitor - Black @ £514.99 inc VAT
The HZ27WA and HZ27WC are Hazro's new line of WQHD resolution monitors built around LED backlight IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The HZ27WA features dual scalers and a glossy 10bit S-IPS panel capable of displaying 1.07billion colours. This extended pallet outputs brighter, crisper and sharper content allowing for separation and distinction of colours not otherwise possible on traditional LCDs. With HDMI, DVI and Component (Y/Pb/Pr) inputs, interacting with high definition video and media input has never been easier.
Features:-
- LED Backlight Standard Color Gamut S-IPS
- 2560x1440 Resolution
- 178/178 Viewing Angle
- 420cd/m Brightness
- 6ms gtg response time
- 72% NTSC / 100% sRGB coverage
- 1 x DisplayPort
- 2 x HDMI
- 1 x Dual Link DVI-D [HDCP Supported]
- 1 x RGB VGA
- 1 x Component Y/Pb/Pr
- 1 x L/R RCA Audio
- 2.5mm Audio in & out
- SPDIF Optical Out
- 1 x USB [service port]
- Kensignton Security Port
- 10bits [1.07Billion colors with A-FRC]
- 27” Diagonal 68.47cm (WQHD), 59.67x35.57cm visible area
- 1000:1(Typ.) / 1,000,000:1(Dynamic)
- Dual Link DVI-D Cable, HDMI Cable, VGA Cable, 2.5mm Audio Cable, 24V External
- PIP Supported; 1:1 mapping/ Aspect Ratio
- Tilt: VESA 100x100 (M4 thread]
- Speakers: Yes, 5W Per Channel; max 10W
- Only available to customers in the United Kingdom
- 3yr RTB Warranty (UK customer only)
Was [£599.99] Inc. VAT
Only £514.99 inc VAT.
ORDER NOW
Samsung S27A950D 27" 120Hz 3D Widescreen Ultra Thin LED Monitor - Glossy Black @ £559.99 inc VAT
Samsung’s 750 and 950 series 3D desktop 3D monitors feature high refresh rate, incredibly thin bezel and stylish design. These monitors are able to analyze and render 2D content in real-time to 3D, supporting PC content, Blu-ray films and gaming consoles. The monitors feature a built-in glasses sync emitter, and they are packaged with a pair of 3D active shutter glasses.
Viewers will experience deep, rich colours and image clarity with Samsung’s new Ultra Clear Panel technology, which combines the vibrancy of a glossy display while maintaining the ease of viewing afforded by an anti-glare matte finish. The LED-backlit panel boasts 100% sRGB coverage to produce realistic colour reproduction.
Features:-
- 3D Active Glasses are included
- TRUE 120Hz
- 2D - 3D Conversion technology
- Screen Size: 27" Widescreen
- Contrast Ratio: 10000000:1
- Response Time: 2ms (2D) / 2ms (3D)
- Inputs: 1x HDMI, 1x DisplayPort, 1x Dual Link DVI
Only £559.99 inc VAT.
ORDER NOW
- VESA Compliant
- Weight: 4.2kg
ORDER NOW
Features:-
- 1 x DisplayPort
- 2 x HDMI
- 1 x RGB VGA
- 1 x L/R RCA Audio
- SPDIF Optical Out
ORDER NOW
Features:-
- TRUE 120Hz
ORDER NOW
