This should help you (its about bf:bc2 but the theory should be the same)Your sig explains your love of the recon class then !
I'm really struggling with snipers, never seem to accurately guess the bullet drop.
I was playing recon, with a sniper rifle at the time. Don't think I had anything to give my team? a radio beacon but that's only for my spawning isn't it?
Your whole squad can spawn on your radio beacon.
But then I have found that some people will just put their lasers/tactical light into your soldiers face for no reason at all. Even more so when you move to get out the way and they just move to face you again. And yes I always make sure I have whatever I have, may it be ammo, health create out at all times when around people...
Your squad can spawn on it, but if you do it disappears.
I miss the tracer dart from bc2, that was fantastic for showing your displeasure to idiotic squadmates (like heli campers and such like)
i really dislike operation metro
which is the better bolt action sniper in BF3 ?
Using the SKS at the minute as it came with my PWP but the low damage is starting to annoy me.
wait till you get the M98B oohh baby i use it for CQ as in 5m lol fit a 4x acog on it and you can rule the map got a 3 for 1 on metro with that rifle lol well i thought they were just standing all in a neat row and bam![]()
Capturing the flags gives you loads of points, also the marksmen bonus for long head shots.
Recon is probably the slowest class to lvl up, just stick at it.
depends on how good you are at it, i maxed it out in 4 hours ish, i didn't just use the sniper rifles though i used the shotguns and other weapons in the recon class while going for flags
