Christmas Weekend Stocking filler Deals 2 - Keyboards and Mice!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys
Thought I would offer you a range of input devices to fill your friends and families stockings!
Logitech G400 3600DPI Gaming Mouse (910-002279) @ £24.98 inc VAT
Set your sights on victory. With a high-precision optical engine, the G400 gives you consistent tracking and precise aiming no matter how fast you move your hand.
Instant access to four dpi levels lets you shift from pixel-precise targeting to lightning-fast maneuvers. A sculpted comfort grip, low-friction feet and eight programmable buttons keep you comfortable and in command.
You've got the upper hand with precision targeting and pinpoint accuracy. Your mouse communicates over USB at a blazing-fast 1000 reports per second - as fast as USB can go, and eight times faster than standard USB mice.
- Weight: 133 g
- Connectivity Technology: USB
- Movement Detection Technology: Optical
- Buttons Qty: 8
- Movement Resolution: 3600 dpi
- Performance: 1 ms response time, 5.8 megapixels per second, realtime sensitivity switching 400 - 3600 dpi, 25 G maximum acceleration
- Features: Programmable buttons, sensitivity adjustment, polytetrafluoroethylene (PTFE) feet
- Cables Included: 1 x USB cable - integrated
- 3 years warranty
Was £29.99 Inc. VAT
Only £24.98 inc VAT.
ORDER NOW
Logitech G510 Gaming Keyboard (920-002762) @ £66.98 inc VAT
Get instant access to the tools and intelligence you need to win. The Logitech® Gaming Keyboard G510 delivers the features you're looking for when losing is not an option. Get real-time game stats and PC performance data with the GamePanel LCD. Keep keyboard controls in plain sight day or night, with custom-colour backlighting. Integrated USB audio provides 3.5 mm jacks for speakers, headphones and microphone. And 18 programmable G-keys with three mode states each allow up to 54 pre-set macro combinations, or you can create new ones on the fly. Requires software installation.
- GamePanel LCD provides in-game stats, VoIP data, media information, system performance and more information without interrupting gameplay.
- The customisable backlighting can be configured to display a wide array of colours, including white, for playing in low light or the dark.
- Integrated USB audio lets you use your own headset with convenience and high-quality digital sound, and independently control game audio output and headset microphones.
- 18 programmable G-keys give you up to 54 possible macro combinations per game. Perform either single keystrokes or intricate macros with multiple keystrokes, mouse events, user-defined delays and repeating*.
- 500 Hz report rate boosts USB connection performance, delivering speeds four times faster than standard USB keyboards.
Was £76.99 Inc. VAT
Only £66.98 inc VAT.
ORDER NOW
Saitek Cyborg V3 3200DPI Gaming Mouse @ £18.98 inc VAT
Cyborg Games controllers designed so perfectly you won't know where you end and the hardware takes over. Controllers with reflexes as fast as your own.
Controllers that fit you better than a glove and look so good that you'll want to show them off.
The Saitek Cyborg range takes gaming performance to new levels, improving control, heightening the sense and helping you realize their true potential.
- Uniquely shaped for enhanced comfort over long gaming sessions to help you decimate your enemies
- Cutting-edge design and extreme precision gives you total control and accuracy to outgun your opponents
- High performance 3200dpi laser technology for instant response and lethal accuracy
- 6 buttons including 3 thumb keys, perfectly positioned for fast gaming action
- Mode button enables 3 different commands for each button
- Rubberised wheel for easy, smooth scrolling
- Ergonomic, sleek styling creates the optimum gaming position
- Black rubber coating increases grip and comfort for hours of fatigue-free gaming
- Teflon feet for smooth motion over any surface
Was £21.98 Inc. VAT
Only £18.98 inc VAT.
ORDER NOW
Gigabyte M6880 1600DPI Gaming Mouse @ £8.99 inc VAT
Ergonomic & total-comfort design: Comfort shape with soft rubber grips provide you a superior grasp even in the longest gaming sessions.
- Interface: USB
- Tracking system: Laser precision
- Resolution: 800 / 1600 dpi switchable
- FPS (Frame rate per second): 3000fps
- Maximum acceleration: 20G
- Maximum speed: 28 inches/second
- Cable Length: 1.5m
- Dimensions: (L)127 x (W)75 x (H)42 mm
- Weight: 145g
Was £11.99 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
OcUK Black Gaming Keyboard @ £8.99 inc VAT
Gamers who like first person shooters will enjoy this keyboard. The Emprex 5105G series keyboard is regular sized and has standard keycaps. Its 104 keys are provided with low noise and high touch sensitivity. There are 3 hotkeys for volume up, down and Windows Logo Lock Key.
- Anti-ghosting capability for up to 11 keys
- 20 million keystroke life
- Windows Logo Lock Key to prevent interruption of gaming sessions
- LED indicators for Caps Lock, Scroll Lock, Num Lock & Win Lock
Was £10.99 Inc. VAT
Only £8.99 inc VAT.
ORDER NOW
Interesting logitech keyboard. Any idea if it can display GPU readings instead of having to use afterburner?
I'm assuming it's the same as the G15 (which I have) which means there are a load of apps oyu can get for showing different things on the screen, but from what I remember, to be able to show the GPU temps & usage etc, you can use afterburner.
