Am I the only one who finds it rather odd?
Aren't these cards supposed to be like uber low on nm and thus power and heat?
Why would they need a cooler like that (looks like a foot long, btw) and a 6 and 8 pin then?
Or is it another case of fail by AMD?
28nm will lower the power usage, and heat, at a given performance point. The performance point of these cards will be similar to the 6990 but will use about 50-60% of the power that a 6990 would.
New processes aren't about enabling lower power graphics cards, they are about building something that is financially impossible on the previous process.
In other words, they probably had finished, boxed, ready to ship 7970's as of potentially up to 6 weeks ago..... just at no where close to launch ready supply.
EDIT: Would seem they are further along than I was thinking I'm probably too used to nVidias development cycle :S just a bit strange we haven't had more leaks from AIBs at this point.
But it still needs the same power connectors?
Surely if it needed 50% of the power it would use a single 8 pin?
I agree nVidia has been a bit tighter on info lately, but I had no problems getting details on the 69xx cards last year.
) AMD could still be tinkering with clock speeds/voltage/shader combinations to get the most possible usage of the wafer..... though that likely would be 7950's that are liable to change unless they have an Nvidia type problem and have to cut shaders off the top part too. But it still needs the same power connectors?
TF3 are silent at below about 35% fans, what are you doing to require the fans to go so high?
No offense, but how is the airflow of your case, and how much gap are there between the top and lower card?I have 2 6950s clocked at 900Mhz and they are noisy as hell. This doesn't happen in every game, but in BF3 they wind up within minutes.
At the moment MSI Afterburner reports the fan speed as 44% for the top card, running idle at 52 degrees, and 40% for the bottom card, running at 37 degrees. The top card is running hotter because I'm using dual screens. The fans kick in to stop the cards going above 80 degrees, and they are very loud at that point.
Thinking of replacing them with a 7000 series card/s rather than replacing the coolers, but I'll have to see how the figures work out.
