Hi,
Looking for recommendations for an upgrade to my current system. Would be used for light gaming (Diablo 3 / SkyRim) and watching films. Don't currently have a graphics card so will need to get one.
Haven't got the budget to replace the entire system I don't think unfortunately. (Budget £200-£220)
Current system:-
AMD Athlon II X3 435 2.9GHz Socket AM3 1.5MB L2 Cache Retail Box Processor
Sony AD-5240S 24x DVD±RW DL Internal SATA Black Bare Drive - OEM
Gigabyte GA-MA785GMT-UD2H 785G Socket AM3 DVI VGA HDMI Out 8 Channel Audio MATX Motherboard
Coolermaster Elite 341 MATX Case
OCZ 400W Stealth XStream PSU - 140mm Fan 1x PCI-E 4x SATA
Kingston 4GB (2x2GB) DDR3 1600MHz/PC3-12800 HyperX Memory Kit CL9(9-9-9-27)
Arctic Cooling Freezer 7 Pro rev 2 Socket 775, 1156, 1366, AM2, AM3 Heatpipe CPU Cooler
Was thinking of getting the following:
AMD 960T (With plans to OC it)
http://www.overclockers.co.uk/showproduct.php?prodid=CP-315-AM
OCUK 6850
http://www.overclockers.co.uk/showproduct.php?prodid=GX-174-OK
- Will that memory be enough to run those games ok or worth getting an extra 4Gb?
- Will the PSU run that GFX card?
Thoughts?
Thanks for your help!
Current system:-
OCUK 6850
Thoughts?
