Exactly, so when you change 2 in 14 million to 1 in 7 million, they believe that they are suddenly much more likely to win than they actually are.
Yes, they have double their original chance to win, but they have not halved their original chance to lose.
I don't think anyone believes they are "much more likely to win". It does double your chance of winning, chance of losing is irrelevant and I think you should put the spade down and stop digging that hole you're in.
EDIT: In response to the OP, it really makes little difference which draws you are in, putting all of your entries in the same draw will make you no more likely to win anything than having single entries in multiple draws. Ideally this is assuming the same odds in each draw but the change will be insignificant either way.
