Afterburner instant BSOD even with 1mhz change
25 Jun 2011
Aberdeen
As in title really, finally decided last night to take my cards higher than 840/1325, managed 880 on the core last night leaving memory alone, tried the same tonight and no matter what I try I just get an instant BSOD.
Even shifting up 1mhz to 801mhz does it :(
Any ideas?
Its AB 2.1 beta 10 afaik.
the latest AB can cause problems with the latest driver , i was told by the writer of AB it's amd's driver's are at fault .
makes rage run at 17fps for me when running the latest AB
Ahh sorry, I was getting mixed up with 2.2 beta 10 and regular 2.1.
I'm on 2.1, it doesn't indicate if its a beta or not, going to give 2.2 Beta 10 a whirl.
Looking at my download history it seems I WAS on 2.2, though which beta I couldn't say, it said it was going to expire on the 15th Jan so I updated, grabbing the first 'download' button I could see on the AB web page.
So could going from a 2.2 Beta down to 2.1 be the root cause of the issue? some conflicting files perhaps?
Edit: Well I'll be damned, going back up to a 2.2 beta and no more BSOD, Afterburner must not like dropping down from 2.2 to 2.1.
Cheers fellas :D
Cheers fellas :D
You was on 2.2 BETA 9 then (thats the one that expires on 15th). Atleast its all working now :)
