- 18 Mar 2010
As per title how c good is a ps3 for; blue ray, digital tv record, iplayer & streaming from pc?
Situation as it stands:
I have a very nice 46" Sony tv, that I feel is being wasted as it is nearly never used for hd content, as I don't have sky, and don't have a blu ray player.
I have a digital recorder that is consistently useless. It regularly misses programs and needs replacing.
I was therefore wondering if getting a ps3 might be a solution to both these problems? I believe if you buy the play tv accessory your ps3 can be used as a digital recorder. Have any of you done this? Is it any good?
I believe the ps3 can also be used to watch iplayer? Is it any good for this? How is the interface?
I Have also heard that I would be able to stream media from my pc, is this correct? Is it simple to do?
It would primarily be bought for the above, rather than gaming. Is there a more cost effective solution? (e.g buying a combination of digital recorder and blu ray player that could achieve all of the above) if so what is the price difference, I think the ps3 + play tv would cost £240.
