The 8 cylinder E39 doesn't handle as well as the 6 cylinder E39 for two reasons - firstly it doesnt have quite the same weight distribution as the 6 pot and secondly as mentioned previously because of packaging reasons the 8 cylinder has an old-style recirculating ball steering system which lacks the feel of the rack and pinnion setup in the 6 cylinder models. This is actually true of the M5 as well - it's not as bad on the M5 because they have a different steering box (Which 540i owners sometimes retrofit) and standard fit Servotronic but even the M5's steering isn't as sharp as that on the 6 cylinder. However the M5 is sufficiently better in almost every other way that nobody buys a 6 pot instead purely on steering feel.
If you just want a point and squirt uber-auto-barge this probably isn't a big deal.
Forum wise I find the American forums can be a good place to hang out to get technical info etc. They seem a lot more hands on.
If you find an online resource for brochures and detailed spec listings please let me know as I've been after such a thing for some time!
. Does the smoke of oil burning off in the plug wells then get sucked into the cabin through the fans whenever you pull up to a stop? Yipeee
