- 4 Jan 2012
Firstly, I wasn't sure whether this is a software or hardware question so I decided to place it here, my apologies if this is in the wrong place.
So recently, I've decided to update my motherboard to the latest update. Everything went fine, albeit a little hiccup; got booting priorites wrong as well as the fact that it switched from ACHI to IDE. Anyway, I changed all that back and now everything seems to be running fine. I've noticed that there's a Marvell controller, as well as a boot-up option. I've set it to ACHI mode as well, but disabled the boot up. Basically, after it shows the motherboard splash screen, it displays an error message saying that it can't find boot-up device. However, it then boots up to my login screen, so it's there for only a split second.
No harm, but I kept it disabled. I have a Asrock Extreme 4 Gen 3, my primary boot-up device is a Corsair Force GT 60GB SSD which is set to SATA0. Should I keep the Marvell Boot Up disabled?
Thank you!
Thank you!
