***Official Unigine Heaven DX11 3.0 Benchmark Scores***
Man of Honour
13 Oct 2006
How much does the cpu effect Heaven out of interest?
Minimal - only really low end CPUs or really old ones will show any significant impact and it mostly hits the min fps as the benchmark takes a bit longer to stabalise at the start which is where the lowest mins usually happen.
Man of Honour
13 Oct 2006
That happens with some gpus/drivers it doesn't grab the framebuffer correctly, you will prolly need to use the screencapture feature in fraps, msi afterburner, etc.
16 Oct 2009
Essex
Right so far I believe weegill (http://forums.overclockers.co.uk/showpost.php?p=21534523&postcount=23) is the only person who has correctly submitted a result.
Please take a look at the rules and follow weegill's example guys.
I'm also using Google Docs to collate the data so will include a link to the spreadsheet when there are more results.
Ta
He also broke the rules (like many others in this thread) by posting oversized images. :p
And what's the point in adding overclocking software to the thread, it's not like it changes anything.
13 Jan 2004
Ta
Fixed mine to the rules as far as I can see :p
http://forums.overclockers.co.uk/showpost.php?p=21538698&postcount=56
Cannot write voltages as the 680 does what it wants with them :p
Seems to be around 1.16Volts from what I can gather from PrecisionX though
21 Sep 2009
London
16 Oct 2009
Essex
Same here, fixed my post, hopefully according to the rules now.
http://forums.overclockers.co.uk/showpost.php?p=21538138&postcount=50
I still think it should be 1920x1080 only and the Heaven 2.5 thread should be reopened as it contains a large database and would be suitable for users with lower resolution screens.
OP
5 Jan 2007
Smallbrook
Thanks guys - but you have some very strange aspect ratios on your monitors :p
I've emailed a mod asking if it is OK to post 1920x1080 screen shots - not had a reply yet.
1 Feb 2009
heres mine:
2 x ati sapphire toxic hd6950 in crossfire @ 1920 x 1080
standard clocks card ships with:
Gpu clock : 880mhz
memory clock : 1300mhz
http://www.techpowerup.com/gpuz/865f8/
14 May 2011
Lincoln
I think leave the screens at native res but crop them so u can see the result and some of the cobbles at full detail and stick to the forum rules :)
