- 18 May 2010
- London
Might be of some interest to some of you.
Very good read, looks like the 680 performs better in newer games.
Not really, you can see its lead at higher res is cut down, fast at higher res, with games dropping from 25% ahead to 10%... this is with some level of auto overclocking, meaning theres usually very little headroom for overclock(vs stock results, you might overclock from 1000 to 1150Mhz but at stock you might be running 1100Mhz anyway, or more), while a 7970 almost all hit 1100mhz, a good 20% overclock and often more. meaning overclocked 7970 is likely to beat it in surround basically every time.
, the part i'm interested in is the 2560 x 1600 resolution and as we see that resolution still takes a huge hit grrr. Waiting for the GTX 780 or GTX 785 and see if they cure that problem atleast so there is not such a huge hit and games run at a decent framerate. So far sticking with the GTX 580 and the 1920 x 1200 screen. I want to update my screen to a 2560 x 1600 before I update graphics again and none of the current single GPU cards can run decent frame rates on 2560 x 1600 and not interested in SLI at all or Crossfire.My 680 hit 1200MHz comfortably and the overclock actually acts more like an underclock in practice. For instance, when I played Skyrim (2560x1600, max settings) my card downclocks to 990MHz for much of the time but cranks up to over 1200MHz during the more demanding scenes, all the while staying above 60fps. It just means the card runs cooler and quieter, which I definitely appreciate. The assumption that it would be a poor overclocker just doesn't seem to match the reality.Not really, you can see its lead at higher res is cut down, fast at higher res, with games dropping from 25% ahead to 10%... this is with some level of auto overclocking, meaning theres usually very little headroom for overclock(vs stock results, you might overclock from 1000 to 1150Mhz but at stock you might be running 1100Mhz anyway, or more), while a 7970 almost all hit 1100mhz, a good 20% overclock and often more. meaning overclocked 7970 is likely to beat it in surround basically every time.
Perhaps even better due to cool running and low noise on top of that monsterous performance. Apart from the price, GK104 is probably the best GPU in terms of performance per transitor, per watt, and per degree of heat ever. It also offers far more features and innovations than the usual single generation jump.That review just reinforces my initial thoughts 680 gtx is the best card Nvidia have realeased since the 8800 gtx.
It's epic.
Oh goody another one of these threads.
