360 Rad fan wiring
25 Mar 2010
North London
I am hoping to run my 3 120mm rad fans from a single fan controller output so I have control over them as a unit instead of individually. Is this possible simply by wiring the 3 in parallel to one 3 pin header plug then into one of the controller channels or would there be a power issue?
If not, any other way of controlling all three as a singular unit???
13 Jul 2009
Llanelli
Provided your controller can handle the current it's fine. You can buy one of those splitter cables. All they basically do is split the 12v and Ground wires off to three fans, while only one gets a tach wire.
13 Jul 2009
Llanelli
I think that might be a bit of a squeeze to fit three wires into the fan connector terminal. They aren't particularly big terminals and will probably provide a poor termination over three wires.
22 Sep 2008
Liverpool
Most controllers can run at least 4 fans of a single channel.
Can you quantify that? Are you saying that most fan controllers have an op amp that has a power ratio >4x greater than they need?
If this is so, I'd urge caution with the heatsink that's mounted onto the opamp as with one connected (http://www.overclockers.co.uk/showproduct.php?prodid=BB-007-ZA) it gets just hotter than I can bear to touch.
I've got 2 of these fan controllers so I know they're not faulty... they just run hot. If you mean the one on the motherboard... PASS.
25 Jun 2011
Aberdeen
Have two fan clusters on my fc5, one with three fans the other with four. No excess heat, handles them really well. Afaik most lamptron fan controllers have a high Watt per channel setup, the fc2 probably taking the most.
13 Jul 2009
Llanelli
How much current a fan controller will handle depends on it's components. If it uses cheap voltage regulators and heatsinks then it'll handle no more than maybe 1.5 fans without getting very hot.
The higher end ones use better components, ones that handle higher currents and waste less energy as heat. These components tend to cost more so the overall price of the unit goes up.
Always look out for the amount of Watts or Amps that a fan controller can handle per channel. Anything in single figures is good for one, maybe two fans. Anything in double figures is good for three fans. The Lamptron with 45W per channel is awesome and could handle as many as ten fans per channel.
22 Sep 2008
Liverpool
It's obvious when you put it like that. I've never really looked at the Laptron ones before - this explains why they are so popular in modding circles.
