Should I try and push it past 4.5ghz?
4.5GHz is plenty really but if u are into overclocking and benchmarking and u want to go more and have some cash to spend then watercooling is an option to look at, what voltage are u running now ? i ask because other than reducing noise it's a bit dependant on the chip u have and even with better cooling u might not be able to get that much more out of it.
Managed to overclock it up to 4.7ghz but the temps rose to 90c while running intel burn test after a few seconds i switched off the pc to protect the cpu and reduced the clock. the voltage is set at 1.35v, how can I reduce this? im tempted to go and buy artic silver to increase the conductivity will this help
Buy a better cooler or just be satisfied with 4.5ghz and prolong the life of your chip.
Scary...
Go back down to 4.6Ghz & see how far you can reduce the voltage to lower your core temps & find the best balance of performance, temps & cpu life. Lowest voltage clocks are just as much fun as highest clock speeds
images
same for 4.6ghz :S I think I need better fans and a better heatsink to be safe. i was thinking of buying two of these http://www.overclockers.co.uk/showproduct.php?prodid=FG-059-AK
then i saw this which includes the two
http://www.overclockers.co.uk/showproduct.php?prodid=HS-080-AK&groupid=701&catid=57&subcat=1395
think its worth getting or should i maybe buy
http://www.overclockers.co.uk/showproduct.php?prodid=HS-005-AN&groupid=701&catid=57&subcat=2262
Oh what, you were hitting 90c @ 4.6?
That is hot, I'd say your cooler is not seated properly and or thermal paste needs re applying, as I said you should be able to hit 4.6ghz with an A50 at around 70c with prime.
But really mate, I'd leave it at 4.5ghz, if you must go higher then get a new cooler. I'd recommend the d14 air or antec kuhler 920, there are other good coolers and I'm sure other readers could advise and expand on my recommendations. Be careful mate.
Typically how much extra heat is there generated between stock and 4ghz and 4ghz and 4.5ghz?
stock to 4Ghz - unless its the worst cpu in the world, virtually nothing, turbo is 3.7 on a 2500k, 300mhz is attainable with less than stock vcore virtually on all chips imo. When you start hitting 4.5Ghz, typically looking at a 10-15C increase in my experience, depends on cooling used though as well.
