Couple of quick DSR questions.
16 Nov 2010
Swimming in a lake
Ok, just a few questions about Distance Selling Regulations and how they work..
Who pays the return postage?
If you return the product in 7 days does it have to be unopened/unused? Or can you have used it in that time frame? E.g. tried it out, decided you don't need/want/like it, and return?
I think that's it :)
Ta.
kd
13 Oct 2008
SE London Born and Bred
You pay to send it back and yes you can open and use the product to see if it fits your needs (this is the whole point of DSR), you are just expected to take reasonable care of the product when in your possession.
The company has to refund the cost of the item and anything you paid to have it delivered to you in the first instance.
Man of Honour
24 Sep 2005
The best thing to do is to check the regulations themselves. They are quite detailed, but relatively easy to navigate.
http://www.legislation.gov.uk/uksi/2000/2334/pdfs/uksi_20002334_en.pdf
The issue of who pays for the return of goods is usually a contractual issue between the parties and the seller is required to provide this information (see r.9(2)(b)(ii)).
In relation to your question, the regulations only prohibits the return of goods that are perishable by their nature or used products that contain data or recordings (software, CDs) (see r.13).
Man of Honour
24 Sep 2005
Hmm, ok.
Well what I really wanted to make sure was that the second one was allowed, I didn't mind too much about who paid for delivery :)
kd
Providing you have taken reasonable care of it, then yes. Obviously 'reasonable care' is debateable, but I'd be extremely surprised if a company would dispute this over packaging.
16 Feb 2007
Perfect time for this question, the company i work for bought an autoclave for the lab. Are we able to send this item back under DSR as the unit is much smaller than the dimensions given on the website (you must use a basket which cuts the stated diameter in half).
Man of Honour
24 Sep 2005
You will be able to ask for a replacement that fits the specifications on the website using s.13 Sales of Goods Act 1979 - there will have been an implied condition of this contract that the goods will comply with that description.
Alternatively, you can try using the DSR, but it is likely you will have to pay to return the item.
Man of Honour
24 Sep 2005
The return postage cost is the least of our worries considering the price of the item in question. Thanks for the help.
I think it might be worth adding that if you bought it as a buisness you are obviously going to be out of luck with that route - the DSR only protects consumers, I should have noted that earlier.
16 Feb 2007
yeah i thought that as well. no mention of the basket decreasing the internal diameter by such a significant amount. The only problem is that delays are the last thing we need here.
