Hi all,
Ok, so my head is spinning with all the input and not built a rig since 2009, but what do you think of this spec for SWTOR and BF3 mostly (but no doubt others will follow). Want to play on max settings with fantastic performance.
The list below will all sit on a Sabretooth P67 M'Board which is backed up by an 880W power supply....and would also appreciate suggestions on a good non SSD hard drive of 1 Tb at least....
Final request....anyone use the Bigfoot Killer Gaming NIC and would recommend it (or alternatives)?
Thanks
Ian
- EVGA GeForce GTX 570 HD 2560MB GDDR5 PCI-Express Graphics Card
- OCZ Vertex 3 120GB 2.5" SATA-3 Solid State Hard Drive (VTX3-25SAT3-120G)
- Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
- Corsair Vengeance 16GB (2x8GB) DDR3 PC3-12800C10 1600MHz Dual Channel Kit (CMZ16GX3M2A1600C10)
- Zalman CNPS11X Extreme (Cooling) - Had to get elsewhere as OC dont have in stock.
- Arctic Silver 5 Thermal Compound (3.5g)
Thanks
Ian
Should i now be looking at the Ivybridge 3570Kwhich seems to be only slightly more £ than the Sandbridge i5 3500K but should run cooler and prob better performance?
