Is it best to build up the weight through the sets then?
I'm going to deadlift 65kg today, did 60kg last week.
Do I just start at 65kg and try and do 3x8 or do I do one set of 60 first?
I'm guessing I should start off at 65kg and if I find form faltering then I should lower it to 60? Doubt I will need to though.
Basically when trying a weight for the first time should one just go straight into it after warm up?
I reckon you'd be alright, as you're not going for a 1RM but working sets, it's only a 5kg difference, you'll be fine mate! Good luck!
