- 3 Aug 2008
- Bath, England
i'm going on a raw vegan diet.
Because weekend came and went out and got drunk.
/QUOTE]
Yum!!
Buy the best one you can afford. The £105 one looks fine and should see you through. What you don't want to do is to spend £65 on a cheapo one and find you have to replace it later when it burns out. I might also recommend white, because silver is a faddy colour. It's like the brown of the 1970's and in 20 years you'll wish you hadn't got it in that colour![]()
Just go to a shop and have a look at it. The problem with some of the machines is they cut corners to get more 'features' in. Spie was looking at a multi food processor that looked amazing on paper and impressive in the videos, great price, but when I had a play with one in John Lewis it really felt like they had cut corners on the materials, buttons etc. Then someone on here said their own one had broken something off and the weighing function had failed.Was thinking about going for the £75 reduced from £100. Not exactly cheap. Seems to do 90% everything the more expensive ones do but is more compact?
It's Argos. They don't have the products on display.
Go to a different shop, it's not like Argos is the only shop
You can ask for a 'customer viewing' of the product where they will bring it out before you pay any money and you can open the wrapping and have a look at the product before you decide whther you want to buy it.
Most John Lewis shops have typically got a good selection of food processors.
