3 displays from my 560Ti
had the same card,2 monitors only at the same time. hope this helps
+1 This graphics card can only support a maximum of two monitors at once.
This is the same as all Nvidia cards that aren't in the new 600 series, of dual-GPU design or made specially to support a third monitor.
Thanks. What about running two monitors off of the graphics card and a third one from my motherboard using the HD3000. Is that possible?
The third monitor will not be used for gaming. merely playing SD video, so the HD3000 chip is more than capable.
That's fine :)
