**Official Gigabyte Z77X-UD5H Discussion Thread**
30 Dec 2008
A Pale Blue Dot
10 Jan 2012
NW UK
OC Profiles on Gigabyte Z77X-UD5H Intel Z77 (Socket 1155) DDR3 Motherboard
Reddey85 and Stulid
Hi guys
Is it possible to save OC profiles on the Z77X-UD5H and pass them onto other users with same board and kit?
Lew
30 Dec 2008
A Pale Blue Dot
Caporegime
17 Jan 2010
weston-super-mare
How is it? Is it pretty solid or are there some annoying bugs?
Depends which Keyboard you have I suppose:D
I have a Corsair K90 and it seems that a Beta BIOS comes out that allows it to work in the BIOS screen, then another comes out that breaks it again, then another fixes it again, then breaks it, finally I have the latest BIOS (F8a) and its working again.
But these are Beta so its all experimental, I do have a cheap Microsoft media keyboard that I use a PS2-USB adapter on, this has always worked in the different BIOSes.
10 Jan 2012
NW UK
Cheers dude
Purchased all kit on your recommendations
Still not had the components as yet as OC still waiting for the 680's to come in and are sending it all out together
Hopefully I will have it all this week
Going to go with the IB 3770k as only want a mx OC of 4.5GHz
Will need some help with build on 2 areas, OC'ing and Setting up Windows 7 on SSD
Thanks again dude
Lew
8 Nov 2005
Sheffield, UK
Other than the keyboard issue in the BIOS are there any other niggles you have come across?
How is the latest F6 official BIOS?
It will be spending most of its life at stock speeds so not looking to squeeze every inch out of it. Just want a reliable board with a good layout and handy features.
Caporegime
17 Jan 2010
weston-super-mare
Its been a fine motherboard.
No niggles to report, the F6 BIOS was solid (apart from not liking my Keyboard)
Kickass sound from it though:)
