This is a truly storming deal and there is now ZERO excuse to not buy an SSD for your laptop or PC .......
- SandForce SF-1200 Controller
theres one excuse right there not to buy one.
theres one excuse right there not to buy one.![]()
yea i wouldnt bothereither if i had the rig in your sig
guess you really dont know how an ssd can provide a speed boost to the system.
if you think only those using high end quad core cpus, 8gig ram and multi gpu solutions can benefit from ssd's then you really are clueless.
also to add this may not be a total fail even if it is sandforce based. it all depends on how the end user uses it. the 60gb one may be ok for me to use in my htpc, all i need it for is running xbmc. so even if it dies in that its not a mission critical area. keep an image of the drive just incase it bricks itself.
