The one with a 2 star average review?![]()
Just checked and yup 5 reviews, average rating of 2!
And it is actually the 4th result, thought it was the first
As I said in my mini review, I wasn't expecting good things either, but it turned out to be pretty good in the end
- My screen protectors weren't dirty, if they are dirty then get a bit of tape and stick it onto the protector were the dust is etc. to remove it
- You don't really need a "special" card, cleaner etc. for preparation and application of the screen protector
- Mine was a perfect fit pretty much
Important things to do, is to apply it after someone has had a hot shower in the en-suite and to make sure the screen is nice and clean before application.
Only disadvantage is that if your fingers are slightly grubby/sticky/sweaty, the marks will show up easily and won't get away by themselves unless you wipe the screen.
Btw when i tried launchers out i also lost my highscores, is that meant to happen?
Nope that shouldn't happen at all, the launcher has nothing to do with the games, all have their own files/folders for config files etc.
