- 17 Nov 2005
- Swindon, UK
Great IFR flying tonight.
See you Thursday.
See you Thursday.
I have FSX and the acceleration addon which I believe is auto SP2..?
Yes, Gamespy is fussy so make sure you're all speaking the same FSX.
VATSIM allows you to fly online with different versions.
There is a Jersey EGJJ mentoring session this Thursday on VATSIM:
Date: 14/06/2012
Time: 1830z - 2000z (1930L - 2100L)
ATC Positions: EGJJ_Z_APP
If we took advantage of this, you can do VFR Island Hopping between Jersey, Guernsey and Alderney or VFR circuits at Jersey or an IFR flight into EGJJ where APP would vector you onto the localizer and make better what we did last night.
You'll need a VATSIM account and some ATC lingo to get the best out of this.
If not, we can freestyle..
I'd like to join in if i may. I have FSX SP2 and a gamespy acc but minimal nav knowledge. Will look into Vatsim.
Don't you hate it when you spend 15mins getting the FMC set up and then you accidentally press the hidden click spot for the TOGA on the MCP and end up crashing before you can turn it off and throttle back![]()
I made it at jersey in the PMDG 900 NGX autoland. About a 3rd of the runway left. Used 1/3rd fuel setting and FULL payload.
I did have a Max breaking, flaps 40 (141kts) landing to help though..
it's 19.30 local time. if you're new to VATSIM, then you can fel free to listen in or share a cockpit via gamespy with me and then log onto VATSIM.
I'll be on mumble about 19.30.
hahaTried it again with 100% fuel and 100% payload. Didn't make it past the trees at the end of the runway at Guernsey, let alone onto the runway at Jersey![]()
Steve.
